I've been trying to solve this for a few weeks now, but I can't see what the issue is...
As per the title, why does my 1073/1290 style DIY mic pre work impeccably when I use phantom powered condenser microphones (with gain @ +75db it's noise floor is actually quieter than my RME Micstasy), but when I use dynamic mics it becomes a buzzy, hummy mess?
The mics I've mostly tested with are a 414 and an sm57, but I've also tried a 421 and a schoeps mk4, with no appreciable change in behaviour. The impedance of the 414 is 200Ω, the sm57 150Ω, the 421 200Ω and the Schoeps is 35Ω(!?). I thought impedance might have been something worth investigating, but they're so similar..
It's powered by a linear, 317 based supply.
I suspected power supply noise as everything is mounted in the same metal chassis, but I don't see why it would be so completely perfect with a condenser mic?? Also, when I turn off the power supply (therefore disconnecting the power toroid from the mains) the noise barely changes during the (roughly) 5 seconds or so the unit continues to be powered by the capacitors remaining charge... So it's not mains hum.
If I unplug the dynamic microphone, the noise disappears.
I have pin 1 of both the input and output XLRs going to chassis (a star-earth next to the IEC inlet), along with any cable shields, the carnhill VTB 9046M I/P transformer casing and LED return paths. The audio 0V on the preamp PCB is only used for the preamp circuit, and returns to the same star earth via the power supply.
Any clues? It's so lovely and full with the condensers.. What's the inherent difference I'm missing?
