12V to 15V circuit conversion
1wildthing
Hi there, I would like to insert the attached circuit block in a build I'm working on. This circuit works on a 12V basis but my new build will work at 15V.
All the components used in this circuit seem to work even on higher voltages but I wonder if they need to be adjusted in some values.
Could you please share your thoughts with me?
    267.8 KB
..this is a bandsplitter, overdrive, then re-combining? Note that if you change any of the three levels, the re-combination won't add up no more, and you get phase smear around corner frequencies anyways. No free lunch...
If in doubt, make the 10K/68K resistors around transistors some 20% larger
/Jakob E.
/Jakob E.
Yes, it's something I'm curious about, it's a kind of tri-band overdrive. Thanks a lot Jackob!
