1. My tech buddy is saying a single rail supply should work for UcD250 as long as it's at least 60V.
Is the implication here that you do not have enough confidence to read through the datasheet yourself? The datasheet very plainly says that all the specifications are with +64V and -64V power supplies (i.e. 128V across the supplies, not 60V as your friend seemed to be saying).
The idle current specification for positive and negative rails is different, which could not be the case if there was no internal connection to a separate ground (i.e. if a single rail with no ground in the middle would work, all current going in through one supply would have to go out through the other, so the idle current could never be different between positive and negative supply).
There are also separate overvoltage detection trips for positive and negative supply rails, which necessarily implies that there is some mid-point reference that each rail is measured against.
I don't know why your friend thinks that there is no required reference to ground for both supplies, but that does not match the clear language in the datasheet.
2. The UcD180 would be about maxed out driving these drivers and I like having headroom on amps.
What is the driver impedance and sensitivity, and what SPL are you trying to achieve? How did you determine whether 180W would or wouldn't be enough power?
Also, I'd rather just deal with one module type and circuit. Also, I can get the UcD250's pretty cheap.
Fair enough, using one type of module is often the simplest approach.
3. As far as buffer, that might be an issue with the 250's, not sure. I'll be feeding these modules with a MiniDSP Harmony 8x12 amp/DSP that can either output speaker level (up to 40W @ 4 ohms) or be switched to line level out (I'm guessing consumer -10dB? Not certain....some kind of line level). Would this require a buffer?
Interesting question. The Harmony manual or datasheet doesn't give details on output impedance or minimum input impedance for a line level connection, but the pins are the same for speaker or line connection, which might mean that the same driver is used for both. If that is the case the 1.8k input impedance of the UcD250 would be no problem.
The max output is 5V, which would be +16 dBu or +14 dBV. Balanced output, which actually is a nice match for the UcD inputs.
The UcD250 datasheet indicates that you need 6.8V input to reach maximum output, so if you actually need that power then you would need a buffer stage to provide a little gain. 5V is only 3dB lower than 6.8V, so either an input buffer with 3dB gain, or just live with a maximum output of 180W instead of 250W.
Since the UcD180 already has a buffer it only needs 1.3V to reach maximum power.
4. If I go the UcD180 route, I'd probably just do two 4-ch units, use one to feed mids-tweets up front and one in bridged mode (2ch) to drive each coil of a 500W @ 4ohm DVC sub. I understand this might be less ideal than using one higher powered amp driving both coils in parallel (level matching issues).
I doubt that there would be any noticable difference between driving the coils separately or putting them in parallel and driving with one high power amp. Separate amps might actually be better, it is pretty hard on an amp driving a 2 Ohm load. As long as the amps are driven by the same signal the outputs will track very closely.
I don't know how well using two separate modules in bridged mode would work. That probably would work OK, but you really need more than 360W driving the sub inside a car? What is the sensitivity in the enclosure you have planned?
You might not end up getting any more power in bridged mode anyway with 4 Ohm voice coils, the maximum current output may become the limiting factor. It could potentially allow running at lower power supply voltages if that is convenient for some other reason, or it could allow hitting the max power output without needing an input buffer. I would ask Hypex whether they have any concerns about bridging two modules to be sure, though.
