[quote author="PRR"] > +150V @ 1A phantom power....and use a voltage divider for your heaters.
Offhand, I can't think of a mike-tube that needs 1 Amp. Pencil 0.3 Amps.
OK, say we bring the full 150V into the mike to feed the plate, and drop some of it to the heater. 150V-6.3V= 144V. This is at 0.3 Amps. 144V*0.3A= 43 Watts of utterly wasted heat inside the microphone. (150 Watts of mostly wasted heat if you insist on 150V 1A.)
Put a 40W lamp inside an MXL990, it will almost fit. Power-up and hold it through an entire song. Ouch! Put it in the rubber-band mount. Ooops!
[/quote]
The wattage wasted through a voltage divider could be more like 10W with a sub-miniature running at <150mV A+ and 100V B+. Still probably not friendly.
Even aside from the enormous power (heat) you plan to supply to a delicate mike: A very common fault in mike lines is a broken shield connection. When that happens the mike case can rise to the phantom voltage. You wonder why the mike aint working, wander over to the (grounded) patchbay or console.... 150V shock.
48V was picked specifically because (at that time and place) 48V was commonly accepted as safe. Current EU thinking leans toward 24V as the maximum around untrained people; the 48V Phantom will persist only through inertia.
While XLR are rated over 1A, it's not a great idea if you hot-plug often.
[/quote]
This one was a little bit more for personal use - a vocal condenser with sharp sticks around it so it pokes you in the eye if you go near it. :shock: Also, a separate PSU box.
Phantom power IS power and many electric codes can claim jurisdiction. In the US there are "Classes" of power-limited circuits, intended for doorbells and other small loads. One goal is to limit the energy so a fault can't start a fire. This smells like the very upper limit of "power limited circuits", where you have to wire like "real" power wiring.
[/quote]
I didn't think about fault heating. I guess that's a topic that could be addressed by using a conventionally fused power supply box with a separate cable running out to the mic., which is more like what I had in mind.
Also: sooner or later you will plug a transistor Phantom mike into this line. The 60V transistor inside will break-down. It isn't unusual for Phantom supplies to fail and put out 70V or 90V.... but they don't have 1 AMP of current behind them. (Or even 0.3A.) The mike will explode. And Murphy's Law assures this won't be your $60 MXL990, it will be the Artist's personally owned favorite Big German Brand mike.
[/quote]
I should have clarified a bit on what the mic's purpose was and what the layout would be. I surely would plan on using a separate PSU box, and NOT try to phantom one of my preamps with 150V.
