It's not an isolation xfmr. It is a step-up xfmr. Without it, B+ would be about 160V, which is not enough for producing decent power with tubes.FarisElek said:I noticed that the mains were connected directly as well. What is the point of the isolation transformer then?
What is the B+ voltage and the tube complement?FarisElek said:Does anyone know anything to give the amp more volume? I feel like the amp isn't even getting loud enough to break-up. I figure this could be power related due to the old can cap, but I'm not sure. I know this amp wont be loud no matter what but I'd be surprised if I couldn't squeeze out 10db more tbh.
The clean output power can be estimated by reding the output tube datasheet and measuring B+. Then you choose a loudspeaker with a rating about twice the power.The speaker doesn't say anything about what is rated. There is plenty of room in the chassis for a 10 or 12" speaker. What's the protocol for figuring out speaker rating?
The trem circuit operates when the jack is not shorted. The schemo a non-shorting jack so it should be on when no plug is in. It's probably faulty.The trem circuit isn't working but I think maybe I just need to turn it on via foot switch which I don't have one with a 1/2" jack on hand.
abbey road d enfer said:What is the B+ voltage and the tube complement?
I dont think you can expect more than 4-5W out of a single bottle.
And the two stage implementation does not cater for high-gain.
Regarding the impedance, you need to measure the CD resistance of the voice-coil (you must disconnect the speaker for that). The nominal impedance is about 1.2-1.5 times the DCR. Tube amps are quite tolerant regarding the actual load impedance (the impedance of a loudspeaker varies a lot with frequency).
On a more general note, don't try to make it what it is not. It's a small low-power low-gain amp (really a student model) that can sound nice for clean tones. You may want to use an overdrive pedal but it won't be a Marshall.
