Hello,
I would like to build a passive box that would allow me to combine the output of 2 Dynamic microphones to feed 1 Mic preamp input only.
This is handy sometimes when I don't have enough channels on a Console or in the Multicore cable that feeds the console.
I would like to use this to combine the 2 snare microphones, Top and Bottom.
The box would have switches for polarity reversal on each mic input, and I would like to have a variable pad for the snare bottom mic.
Can someone please recommend me what variable pad should I use for this application? Can I use a dual gang pot for the variable pad?
Also how should I combine the mics, just parallel the two microphones to the output or do I need any summing resistors?
thank you so much
thank you so much
