I have an EQ that needs to be loaded with 200 ohms. In order to run this into a 600 ohm preamp's input, can I simply put a 300 ohm resistor across the EQ output to divide the 600 ohm impedance to 200?
It works in simulation, not sure if it would cause any undesirable effects in reality.
