sardonic_z
Member
- Joined
- Dec 20, 2012
- Messages
- 9
Hey there everybody. I have been tasked with powering some Scully 280 mic pres, and I want to equip them with phantom power, cause, you know, it's 2013. The Scullys run off of -24VDC. I saw a post from Jakob of Gyraf on a similar thread (someone was trying to get +24 and +48 off a single supply) where he suggests using a ±24v supply, running the phantom between the positive and negative terminals, and then just getting the +24 by referencing ground as the positive voltage.
Will this type of idea work if I need -24? IE I could get the 48v from the pos and neg added together, and then take the -24 from either the -24 terminal and ground, or from ground and the +24. I just keep getting confused about whether that screws up the grounding for the whole module or not. I see no compelling reason why the two power sources need to share a ground, EXCEPT maybe the way phantom power works, EXCEPT maybe that's not such a big deal etc etc.
Please, help out a relative noob.
