25k rev log
louder
portugal
alo
looked everywhere,but no luck finding 25k rev log,here in europe.
does any of you,knows where i can buy them?.
best regards
pedro
The best place to look is at the companies repairing audio related stuff. They may have some as spareparts. You won't find them in "normal" electronics parts shops.
Jakob E.
You can find dual 22k RLOG pots here. http://www.electrovalue.co.uk/pdf/pot.pdf
Just use one track They're £1.68 a piece for a 20 mm Omeg pot. It sounds like a bargin to me.
elco
I have received very good response & customer service from CTS through their local rep in Sweden.
They made some pots for me among them 10k revlog.
They manufacture to order and there was no problem with 10pcs/value.
However, be carefull when ordering linear pots and specify 300degrees mechanical AND electrical rotation or you'll get joystick pots with +-25 deg electrical rotation - happened to me but they replaced 40 pots without question.
http://www.ctscorp.com/components/potentiometers.htm
alo
thanks
called electrovalue,and ordered ten pieces(now,i have to build ten api pre`s).
thank you so much.
best regards
pedro
alo
why?
easy:
because that`s what the masterminds here at lab say.
sorry,andre(just joking).
you can use a 25k rev log(22k),or use a 12 position switch.
i don`t know much more.
best regards
pedro
alo
why?
easy:
best regards
pedro
SSLtech pointed out in a previous post that a 50k reverse log pot is the same as 25k rev log through 90% of its rotation. They're much easier to find - stock Fender amp parts. If you look up his post and read his explanation in more detail maybe that will work for you.
Good luck :thumb: :thumb:
