I am building a G9 p2p and, having mounting everything except the pre circuit, I fired it up today to take the first measurements of the power supply and 12 vdc for heaters and 48volts for phantom power. Since there is a 10k variable resistor to adjust for the 48 volts it is very easy to get it just right.
Now… since I am a half blind man I wanted to add a led to mark that the phantom power is on. Since the draw is 1,2 volts and there are two channels I lose 2,4 volts from the 48.
My question is… Is it ok to set the phantom power to 50,4 volts to be able to operate two channels with the 48 volts each…or should I set the trimmer on 48 volts and accept that the phantom power is 45,6 volts when using both channels?
/John
/John
