Making_Waves
Member
- Joined
- Nov 1, 2012
- Messages
- 10
Hey everyone, I've never posted on here before, but a friend suggested I should post my most recent project here.
I made a 4 channel balanced, passive microphone splitter based on the Jensen application note 005. For the enclosure, I gutted the ART P16 XLR patch bay, created my own pcb, and threw it in the enclosure.
I decided to make it because there didn't seem to be many options with passive mike splitters on the market. I chose to use the ART P16 patch bay to save a lot of time, money and effort by not having to search for the right sized enclosure (the P16 is not very deep for a 1 rack space unit), not having to buy XLR connections, and not having to drill the holes for the XLR connections.
It can be easily expanded to 8 channels, just use 2 PCBs, and double the quantities of parts. The following part list is listed for only 4 channels.
Cost
Mouser part numbers are given for everything but the transformers
Jensen JT-MB-CPC x4 - about $230
ART P16 XLR patch bay - I got mine used from guitar center for about $70
Rocker switch (612-RD1113112R) x4 - $2.68
51 ohm resistor (279-LR2F51R) x8 - $.88
2.7k resistor (603-MFR-25FTE52-2K7) x4 - $.48
.01uf capacitors (505-FKS2D021001B00JI) - $1.44
circuit boards - $35 for 5
Total for four channels: About $330
For 8 channels, you wouldn't have to buy more PCBs, or another enclosure, just more transformers and components so for 8 channels, it would be about $560
Here's a dropbox link to my gerber files for the PCB:
https://www.dropbox.com/s/1uvnrk0sq5tm93m/Jensen%20Mike%20Splitter%20v2.zip?dl=0
And you can find some pictures here:
https://imgur.com/a/XcwOE
Schematic can be found on Jensen's website, application note 005.
Clearly, you can mix and match some different components to get the price down. Most obviously, the transformers. I went with Jensen because I didn't want to cut any corners. Also, if I could do it again, I'd choose a different way of approaching the ground lift switch. I had to dremel out a little cut out for each of the switches, and create short jumpers to each tab with some slack so I could move them into place.
So yeah that's it! Again, this is my first post so I'm not sure if I'm missing any info or anything let me know!
Cost
