i tried to search for 5 rails power supply but didn't find many informations. with such helpful replies i made a good choice starting a new thread!
(thanks
- the switch will be only a wire jumper, i used a switch in the schematic because it has a suitable package for the layout
- i forgot to tell that the main use for this psu will be for powering quad ssl9k preamp, that needs +48, +/-15 and +/-18
- so i was thinking about using a 2x18V secondary and setting the jumper as tripler.. am i right? about the current draw i'm not sure, but if i understood the datasheets correctly, the TL052 has about 5mA supply current, as the NN5534, but i don't know the current for the LM394.
I definitely need your help for understanding the expected load current, and in choosing the right power transformer VA rating.
- B1 and B2 are missing values because i don't know exactely what to use. I thinked about a 4A 200V just because i founded it on another project, but let me know tips for choosing the right one
- caps rating are 50V for 1000uF and 63V for 10uF... correct?
- i will change the trimmer configuration for fixed resistor + 100R trimmer, or maybe leave only the fixed resistor as both of you suggested
- would the zener make the LM317 safe enough, or is better to swap for a TL783 in any case?
- i didn't understand the C13/C16 modification, please can you explain?
