strangeandbouncy
Hi Peter,
round meter looks the mutts nuts in there! HubbaHubbaHubba . . .
Kindest regards,
ANdyP
Kindest regards,
ANdyP
jsteiger said:Isn't that the Pye eq?
Crusty2 said:Do you really need a dc convertor? If you have transformer isolation, why not make the -15V the 0V point and the +15V becomes a 30V rail? (Couldn't do a sidechain insert easily though...)
peter purpose said:Crusty2 said:Do you really need a dc convertor? If you have transformer isolation, why not make the -15V the 0V point and the +15V becomes a 30V rail? (Couldn't do a sidechain insert easily though...)
It want's 40V and I'm using an MC34063 to boost the dc.
ruckus328 said:Keep in mind too if you try to power the sidechain any lower than the original 36V you'll be reducing the maximum possible compression, since you'll be limiting the maximum sidechain gain possible to the step up xfmr. If you try to run it directly off the 500/51X 24V supply (I think that's what you meant when you said run it off of the positive rails), I suspect it will have very adverse effects.
haima said:if you need 30v and all i/o is TX isolated, it seems like using the +/-15v as floating 30v makes sense (as Crusty2 suggested)... what's the downside?
peter purpose said:Sorted.... getting 30dB gain reduction with a +10dB input.... nice.
Pulling the right amount of juice too.... marvellous.
