dmp
Put me down for 1 / maybe 2
dmp said:Are the t4 parts going to be easily available? Supplier?
LDR = Light dependent resistor. That's all I know.Ptownkid said:Ok, you lost me here...what do you mean you'll only need the EL panel and LDR's?
Ptownkid said:So what keeps the EL panel from being affected by outside light?
Knowing Peter, he started with the eye of newt and toe of frog. Next came the electronic component gizmo's.Ptownkid said:...What did you do Peter?
Ptownkid said:Is there indeed a box around there, I can't tell...
Does anyone with experience have a ballpark of how many LDR's one would go through in order to match them? What did you do Peter? Did you gut and actual t4b?
jsteiger said:Knowing Peter, he started with the eye of newt and toe of frog. Next came the electronic component gizmo's.
