80hinhiding
- Joined
- Sep 27, 2016
- Messages
- 97
You must have a good reason for wanting a tube mixer, and it has a cost. I think you should really define what you expect. There are plenty of tube gear where tubes are only decoration and plenty of people who buy tube gear just for the sake of saying it has tubes in it. Building a mixer takes a lot of dedication and always cost much more than expected at the end of the day, so you have to assess your motivation.80hinhiding said:If one were to be having so much fun building a mixing console from scratch over the past year and a half that he is planning for the future already, thinking of a bare bones tube line console featuring a trim, gain, panning, level on each channel down to 2 bus output.. on an extreme budget - what could be accomplished from lessons learned already, I wonder?
Are you ready to accept the risks associated with running unbalanced connections? Me, I don't care about "xfmr sound", but I care for signal integrity.For line level, maybe we could get by without an input transformer.
Does "suffice" suffice? I believe you're expecting something special for this project, are you going to cut every corner of it?However if one was absolutely necessary, perhaps a Edcor WSM 10K:10K would suffice.
They would need to be evaluated in view of your expectations; I can't answer this for you. They are quite different tubes; however, in the context of the REDD47's output stage's specifics (large load Z vs. inner resistance, under local NFB), the 61NP may provide satisfactory performance. Some values may need to be adjusted though.Would budget tubes, military stock from Russia such as 61NP-EV work well instead of the ECC88? Except for the high heater current.
Not necessarily, but a good understanding of grounding and decoupling is necessary anyway. You may have to use larger decoupling caps than the ones in the original. remember that lytic caps in the 60's were expensive and bulky; today they are much more cost-effective, smaller and more reliable.Would OA2 voltage regulators be required?
That is a possibility; I used to make guitar amps out of recuperated tube TV's when I was much younger. However, if all you end up salvaging is the PT, you're better off buying a new one; I wouldn't think you'll want to re-use 40 year old caps and rectifiers.What kind of vintage consumer gear might have some key components for a power supply, that could possible be scored for very little? I've seen a Zenith tube radio for sale locally for $40, as one example.
Definitely a bad idea; in addition to the sag issue, you'll have to deal with large current spikes and the need for increased filtering.I was thinking of using a cheap 115V:24V 56VA transformer for plate voltage but by the time you triple that AC the B+ current capacity would be too small for 10 channels I think.
A trick that is largely used consists in having a 115:6.3 capable of handling all the power and use another one (smaller) wired as 6.3:230 for HT. That gives about 290Vdc, which is enough for a mixer. Actually, the REDD47 takes 300V at 20mA for its operation, the rest is dissipated in the regulation (80V in the ballast resistor, 10mA in the OA2's). There is no reason why it wouldn't work at 280V.The power transformers I see that have 220 mA and above are on the costly side for sure.. but might be the one thing to bite the bullet on..
abbey road d enfer said:Does "suffice" suffice? I believe you're expecting something special for this project, are you going to cut every corner of it?
80hinhiding said:Sorry for starting a topic about this..
Adam
80hinhiding said:If I was going to build a full on tube console, I'd go with the Redd circuit, and Ian's Redd EQ schematic on every channel. Transformers everywhere. I don't have that kind of money and as stated already went for broke on the transistor based console I'm already making. I also stated I'm using a twin line amp that I built with tubes every day now, so it has a purpose and it is effective even to have line amps around.
Adam
80hinhiding said:I appreciate all the advice given, except I think Curt and Abbey you might be forgetting I've already gone big on a console that is still in progress now, and I have certainly learned a ton about the huge amount of work that goes into a mixer!
emrr said:Why the REDD circuit? That's the first red flag to me, that I've no indication you've built and auditioned one (maybe you have), and there a SO MANY possible circuits to choose from. You could build 10 of that, and hearing one of something else later could blow your whole perspective up.
abbey road d enfer said:There are plenty of tube gear where tubes are only decoration and plenty of people who buy tube gear just for the sake of saying it has tubes in it.
I understand that, still, you haven't answered the question; why do you want a tube mixer?80hinhiding said:I'm not going for decoration.
abbey road d enfer said:I understand that, still, you haven't answered the question; why do you want a tube mixer?
80hinhiding said:I'd like to do it for fun, to carry on the tradition as well, and for the sound. However, I know this isn't something to take lightly and I am still heavy into my solid state console production which I'm really enjoying, so it's just something to think about/discuss... for now.
Adam
80hinhiding said:Yes, when the time comes. I think you might have missed my earlier post from Feb 05, 2018 in this thread, where I said I would prototype a single strip instead of rushing into the full thing (which is my instinct). I changed my mind on doing one that is really stripped down, based on advice received here and from learning from my mistakes made already it's not a good idea to rush anything too much. It's costly.. and so many factors influence the end result that things need to be tested out if we're to be happy with the product. I do know though that trying things out naively is sort of working for me ha.
But thanks for the reminders everyone.
Adam
