Hi
Maybe I'll replace the transistor amp in my Wurlitzer 200A epiano with a tube amp. I found that the early tube Wurlies used a 6k11 triple triode.
It seems to be quite expensive, but I might be able to buy one.
Is there any reason to go for a triple triode? I saw the bulb is rather stout, compared to normal preamp tubes. Maybe this is an advantage in an invironment of extreme vibrations, like the inside of an epiano?
Any other reasons? Any suggestions what else I could use (except the typical standard stuff)?
JH.
JH.
