I've been messing around with this for a while, and now that I've finally got something working I thought I'd share it with you all! I've picked up loads of good info on here over the years, so nice to finally post this! I had an account here but I can't seem to find my details (it may have been linked to an email account I've binned - too much spam!!). Anyways...
I built a 1073/1290 kit a while back, which mostly worked, so I thought I'd expand it to be something I'd actually use. I'm rarely recording just one or two channels at a time, so a single channel of mic pre isn't going to get used - 99% of the time I'm recording on location, I'm not interested in carrying any more weight than I need!
So I set myself the challenge of making an 8 channel, 2u version - something I could squeeze into a rack and not worry about. It had to have an internal power supply (the weak link, time to do some serious learning!), some sort of metering, and I thought it might be nice to have a HPF - 8 channels of neve on a kit with some decent filters? Drum heaven! I was fully aware that there'd be inevitable compromises from the tight-ish packaging, but I've plenty of modern clean mic pres if that's what was required. So I laid out some circuits and a couple of revisions later I had a working mic pre. It seems very stable and solid, and nice and quiet when using a bench supply - quieter than the RME 12mic I compared it to - a good start! The filter is just the inductor based circuit from the 1073. And I popped a pad circuit on the front of it all.
Next up was a power supply. I knew full well that a linear supply was a bad idea, what with it being inches from the mic pres, but I was impatient to get it moving forward. So it's a +24V, +48V and +15V supply using LM350/317/7815 regulators. And it works nicely of course - even I can layout a linear power supply! And it's not as noisy as I feared.. It's not great, and it's not good enough for what I want, but it's usable in the short term. It's one of those things that I had to hear for myself. You read so much about distance being the key to everything when it comes to linear supply, but now I actually know!
Finally I set about a basic level indicator board - optimistically called my "vu pcb". It's a super basic comparator circuit with 4 LEDs per channel. I'd love to make a proper peak indicator circuit for this, but that's a job for another day. Of course there's been plenty of fudging bits to fit in the case too, but compared to my first revision of this (which was more jumper wire than circuit board!) this is perfection!
So next step is a switching power supply.. I'd love some recommendations on good books if anyone knows any? I know that just putting the linear supply in an external box would solve most of my issues, but I don't want an external power supply.. It's actually something that puts me off buying certain pieces of gear - it's one more thing to pack, one more thing to get tangled... That said, I do want to finish this and move on with my life(!) so any and all thoughts are welcome!
Another thing I don't understand is why the PAD circuit is so crap. It's just a 3 resistor circuit (https://www.jensen-transformers.com/wp-content/uploads/2014/08/as016.pdf), but I get quite a lot of buzz when I engage it...
Lots to finish off!
Lots to finish off!
