CurtZHP
Came up with a Frankenstein's monster of a small level meter circuit built around an LM339 quad comparator I found. Schematic attached.
Component choices had almost entirely to do with what I have on hand.
It worked (no one was more surprised than I was!). I originally omitted the op amp section, but there wasn't enough signal to drive the meter, so I added it primarily as a way to boost the signal to a level the comparator section could work with. The trim pot allows for some "calibration." Seemed to work OK, but when I connect it to the audio circuit I want to use it on, it did seem to load things down a bit. I naturally suspected it had to do with those aforementioned component choices, so I consulted my copy of Doug Self's book, and the section on level meters. It seems I need a high impedance input to this circuit to prevent loading issues. Looking over a few of those circuits, I came up with a revision for mine. I added an input coupling cap to deal with any DC silliness as well. Would that also further isolate this from the rest of the world? Am I barking up the right tree? I haven't had a chance to try this yet, but I will once I get home from work.
