jdbakker
Dear all,
Several of you will know the LM13700 (second sourced as the NJM13700), a dual OTA (Operational Transconductance Amplifier). It is specified as having an (unipolar) supply range of 9.5 to 32V. For my purposes I needed to go quite a bit lower. Looking at the specifications and the functional block diagram (http://www.ti.com/lit/ds/symlink/lm13700.pdf p.9), it seemed that for low voltage use the Darlington buffer might be an unnecessary waste of headroom. Perhaps reducing the output compliance range and the input common-mode voltage could help too?
The attached schematic is the result of this exercise. Signal input is at the left side of C2 (~2Vpp max), control voltage enters at R1. D1-3, R8 and R7 bias the input to the middle of U1's common mode range. Improved Howland current pump U2 applies the CV as a current to the amplifier bias input. With the components as shown CV swing is from 0V (off) to 2V (full). R1/R2/R4/R5 are what I happened to have lying around; for best performance R1 should be a smidge higher (see TI AN-1515 for details; originally by Robert Pease but I see they left his name off in the latest version). The transimpedance amplifier around the other half of U2 plus C5, C6 and R9-11 reduce the swing on U1's output to 'almost' zero (as stiff as a virtual ground on a 1MHz op-amp gets, anyway). C6 could be reduced by at least a factor of 10, but for my purposes stability on a rickety breadboard was more important than audio bandwidth. While way outside the manufacturer's recommended operating range, the single sample I breadboarded appeared to work within spec (as far as I could be bothered to test).
[But why? This is for step two of an Introduction to Electronics-class. The central theme is a low-voltage modular synthesizer, with a VCO+ADSR in a microcontroller, but full analog VCF, VCA, log/antilog, rectifier, peak detector, discrete sequencer and much, much more. In step one the freshmen got to use my pre-made PCBs, now they get to Eagle up their own. The entire system runs on 3.3V because microcontroller, so I needed an inexpensive low-voltage VCA plan for them to use. Of all the contenders, the LM/NJM13700 is still surprisingly easy to get and comes in breadboard-friendly DIP]
Thoughts?
JDB.
Thoughts?
JDB.
