Hi all,
I have an enclosure and power supply wired for two API 325 cards. The enclosure and voltages check out fine when there are no cards in the slots. The two cards check out fine outside of the enclosure. When I put the cards in and turn it on the power transformer immediately starts to hum and the voltage gets pulled down to +/-2V. I've checked my wiring and it's correct as far as my intentions were concerned, but obviously something is wrong.
I have two unbalanced inputs with the shield and the white conductor feeding the low side, though the shield is only connected at the input connector, not at the edge card connector, and the red conductor feeding the high side. The output is through a 25 ohm 10 watt resistor, each card feeding the tip or ring of a TRS output and both output low sides feeding the shield. Gain set is a 100k reverse log pot between pins 7+8.
Any ideas?
Schemo
Any ideas?
Schemo
