*disclamer* a fair amount of the content of my posting will involve the work and ideas of Ian Thompson Bell. Any errors, distortions, omissions and misrepresentations are soley mine, and reflect in no way on him, nor represent his thoughts on any of these matters.
I’m going to try and build a tube tracking console based on the the work of Ian Thompson Bell (ruffrecords), and the design philosophy he sets out for his Mk III Vacuum Tube Mixer, which he sets out on his website:
Custom Tube Consoles
…and in the Blog for his MKIII tube console project:
mark3vtm.blogspot.com
Updates and discussion of the project can be found here on GroupDIY, on this thread:
groupdiy.com
I love tubes. I think that, well designed and implemented, they just sound better than more recent analog technology, and not just better, but different. Somehow they add clarity without harshness, sum magnificently and create a very coherent and open soundstage. This possibly due to the harmonic distortion they impart, but whatever the reasons, I knew that, finding the need for an eight track live recording console (which will get paired with a DSD back end), and having looked at Ian’s tube console designs, I had found a tube solution that would fit the bill - if I could manage to cobble it together…
Here are the design points I am borrowing (to put it charitably), from the MKIII Tube Console design:
- 35mm wide pluggable modules for channels and monitor sections.
- The use of aluminium ‘cheeks’ with aluminium extrusions connecting them to form the chassiss frame. Details of this may seen on Ian’s Blog here: You've Been Framed
- The module design of attaching the PCB to a steel panel, and to the control panel, to form a rigid module that also provides shielding between channels. Details of this may seen on Ian’s Blog here: Come Together
- The basic channel mic pre and monitor section designs, which hark back to Ian’s EZ tuber mixer designs, information about which may be found here: eztubemixer.blogspot.com
- The use of a backplane connector design into which channel and monitor modules may be plugged.
What I will be bringing to the party is, in fairness, very little. Essentially just a few ideas of how to adjust the phyiscal and logical topology of the design to suit my needs - which are:
- Eight mic pres with inserts, HPF and direct outs.
- The ability to mix the eight channels down to a stereo line output.
- Master bus inserts.
- Solo PFL with ZERO effect on the direct outputs or 2bus line out.
- No sends or auxes
- Stereo headphone output (provisonal - not sure it will fit)
- Stereo monitor outputs ( useful for basic mixing/ mastering of live material, since DSD can’t be mixed ITB )
- LED VU PPM meters (led because 35mm module width)
- A shallow(ish) chassis suiable for laying on a tabletop and hopefully transportable without a crane.
This is for me a very tall order, particularly since I am barely literate from an electronics perspective, and I certainly don’t understand most of what the designs imply, but that is the beauty of the situation; Ian has done the heavy lifting and is most graciously allow the likes of me to swoop in and take advantage of it, and I have the brains of this forum to pick for anything else. This process will be very educational and exhilarating and I will end up with a very useful and supelative ( if not heart-stopping costly ) piece of audio kit.
The circuit design will be 100% Ian’s, but it will be neccesary to create my own pcbs for the channel, master section and control panels, as I will need the physical topology to be different.
This will be a ‘portable’ console, so the form factor will be flat - meant to sit horizontally on a surface with the controls facing straight up, and we will see how shallow I can get it. Initally I am thinking of a chassis 100mm deep x 315 mm wide (nine 35mm modules, excluding cheeks and any wooden sides) x 300mm tall.
To kick things off, below is my first attempt at a block diagram which is adapted from Ian’s diagram entitled ‘EZTubeMixerSigFlowsm.jpeg’ in the EZTubeMixerDIY section found here:
drive.google.com
Please feel free to poke large holes in it ;-)
- Richard
Mark 3 Vacuum Tube Mixer
Building on all I have learnt from the development of the EZTube Mixer, I have begun developing the next generation tube mixer. I am recording its development in a blog here: http://mark3vtm.blogspot.co.uk/ Cheers Ian
- No sends or auxes
EZTubeMixer - Google Drive
- Richard
