6072a isn't submini and since is available there's no need to find any replacement.
There's no direct replacement except AC761, which is also rare as 701, also pricey and, from what i know, hard to find good one.
You can substitute it with EF732/5840 tube. Works good enough and probably will need lower cathode resistor - in m49C circuit require 1.6k-1.8k instead 2.2k original value.
