A friend of mine want a RME converter. http://www.rme-audio.de/en_products_adi_2.php
curiosity kill the cat ... well I begin searching info about the RME and it seems to use Cirrus logic ADC, DAC and digital transmiter. by other side focusrite seems to use the same chips for the ADC cards, look at the evaluation board on cirrus page and it should be close.
here is a good list of ADC and DAC manufacturers
http://www.interfacebus.com/Analog_DAC.html
here is a good diy project kit
http://beis.de/Elektronik/ADDA24QS/ADDA24QS.html
I search some ADC and DAC to know what is better , here is the list , at least 24bit, mainly stereo, 5V analog voltage.
ADC
Texas Instruments
PCM4201 24bit SNR (typ) (dB) 112
PCM4202 24bit SNR (typ) (dB) 118
PCM4202-EP 24bit SNR (typ) (dB) 118
PCM4204 24bit SNR (typ) (dB) 118
PCM4220 24bit SNR (typ) (dB) 123
PCM4222 24bit SNR (typ) (dB) 124
Wolfson
WM8785 SNR / THD (dB)111 / -102
WM8786 SNR / THD (dB)111 / -102
WM8781 SNR / THD (dB)102 / -90
WM8782 SNR / THD (dB)102 / -90
WM8738 SNR / THD (dB)90 / -87
Wavefront
AL1101G 24bit 107db
AL1201G 24bit 107db
Thaler
ADC150 18 - 24bit
ADC180 13 - 26bit
Intersil
HI7190 24bit
HI7191 24bit
Cirrus Logic
CS5340 24bit ,dinamic range 101db
CS5341 24bit ,dinamic range 105db
CS5342 24bit ,dinamic range 105db
CS5343/44 24bit ,dinamic range 98db
CS5345 24bit ,dinamic range 104db
CS5351 24bit ,dinamic range 108db
CS5361 24bit ,dinamic range 114db
CS5364/66/68 24bit ,dinamic range 114db
CS5381 24bit ,dinamic range 120db
CS53L21 24bit ,dinamic range 98db
Analog Devices
AD1974 4 ADC with PLL, 192 kHz, 24-Bit Codec, dinamic range 107dB.
AD1871 Stereo Audio, 24-bit, dinamic range 105dB.
AKM
AK4397 - 32-bits, 192kHz, 120dB SNR, -103dB THD, premium sound quality
AK4396 - 24-bits, 192kHz stereo, 120dB dynamic range, minimal out-of-band noise, low power
AK4395 - 24-bits, 192kHz sampling, 120dB dynamic range, differential outputs
AK4394 - 24-bit 192kHz 120dB dynamic range, -100dB THD
AK4393 - 24-bit 96kHz 120dB dynamic range, -100dB THD
AK4388 - 24-bits, 192kHz stereo, 106dB SNR, low cost, parallel control
AK4387 - 24-bits, 192kHz stereo, 106dB SNR, low cost, serial control
AK4386 - 24-bit, 3V, 96kHz stereo DAC
AK4385 - 24-bits, 192kHz, stereo, 108dB SNR, differential out
AK4384 - 24-bits, 192kHz, stereo, 106dB, single-ended out
AK4383 - 24-bit 192K 112dB DSD+PCM DAC, DATT
AK4382A - 24-bit 192K 112dB
AK4381 - 192KHz 108dB DAC; available, but not recommended for new designs
AK4380 - 24-bit 96K 100dB low-cost audio DAC
AK4371 - 24-bits, 48kHz, stereo, low power, PLL, headphone amp, line out, analog volume control
AK4370 - 24-bits, 48kHz, stereo, low power, headphone amp, line out, analog volume control
AK4368 - 24-bits, 192kHz, stereo, low power, headphone amp and line out
AK4367 - 24-bit DAC 8-48KHz with 50mW HP Amp, mixer
AK4366 - 24-bit DAC 8-48KHz with 50mW Headphone Amp
AK4365 - 20-bit 88dB Low-power w/PLL for CDMA, GSM
AK4364 - 24-bit 96K 102dB w/video clock PLL and S/PDIF TCX
AK4363 - 24-bit 96K 102dB with Video clock based PLL
AK4353 - 24-bit 96K 102dB w/integrated S/PDIF TCX+ DATT
AK4342 - 24-bit 96kHz DAC with ground-referenced 2Vrms and headphone outputs
AK4341 - 24-bit 192kHz 100dB stereo with biased 2Vrms output
AK4340 - 24-bit 192kHz 106dB stereo with ground-referenced 2Vrms output
DAC
Texas instruments
DSD1792 24bit SNR (typ) (dB) 132
PCM1794 24bit SNR (typ) (dB) 132
DSD1794 24bit SNR (typ) (dB) 132
PCM1792 24bit SNR (typ) (dB) 132
DSD1794A 24bit SNR (typ) (dB) 127
DSD1792A 24bit SNR (typ) (dB) 127
PCM1792A 24bit SNR (typ) (dB) 127
PCM1794A 24bit SNR (typ) (dB) 127
PCM1796 24bit SNR (typ) (dB) 123
DSD1796 24bit SNR (typ) (dB) 123
PCM1798 24bit 123 (typ) (dB) 123
PCM1793 24bit 113 (typ) (dB) 123
PCM1791A 24bit 113 (typ) (dB) 123
DSD1791 24bit 113 (typ) (dB) 123
DSD1793 24bit 113 (typ) (dB) 123
PCM1780 24bit 106 (typ) (dB) 123
PCM1781 24bit 106 (typ) (dB) 123
PCM1742 24bit 106 (typ) (dB) 123
PCM1755 24bit 106 (typ) (dB) 123
PCM1753 24bit 106 (typ) (dB) 123
Wolfson
WM8740 SNR / THD (dB)120 / -104 Output level (Vrms) 2,0
WM8716 SNR / THD (dB)112 / -97 Output level (Vrms)1,1
WM8718 SNR / THD (dB)111 / -100 Output level (Vrms)2,0
WM8706 SNR / THD (dB)106 / -97 Output level (Vrms)1,1
WM8728 SNR / THD (dB)106 / -97 Output level (Vrms)1,1
WM8729 SNR / THD (dB)106 / -97 Output level (Vrms) 1,1
Cirrus Logic
CS4344/45/46/48 24bit, dinamic range 105db
CS4350 24bit, dinamic range 108db
CS4351 24bit, dinamic range 112db
CS4352 24bit, dinamic range 106db
CS4361 24bit, dinamic range 105db
CS4362A/82A 24bit, dinamic range 114db
CS4365/85 24bit, dinamic range 114db
CS4391A 24bit, dinamic range 108db
CS4392 24bit, dinamic range 114db
CS4398 24bit, dinamic range 120db
Analog Devices
AD1955 Multibit Sigma-Delta D/A, dinamic range 120dB
AD1853 24-bit 192 kHz Multibit Sigma-Delta, dinamic range 116dB
AD1852 Stereo, 24-bit 192 kHz Multibit Sigma-Delta, dinamic range 114dB
AD1854 Complete Single Chip Stereo Audio D/A, dinamic range 113dB
AD1958 Stereo, 24-bit 192 kHz Multibit Sigma-Delta D/A w/ PLL, dinamic range 109dB
AD1959 Stereo, 24-bit 192 kHz Multibit Sigma-Delta D/A, w/ PLL, dinamic range 108dB
Maxim
MAX5556 24Bit, DAC SNR 91dB, 87dB dinamic range.
AKM
AK5394A - 24-bit 192K 123dB, Highest Performance ADC
AK5393 - 24-bit 96K 117dB pro audio ADC
AK5392 - 24-bit 48K 116dB professional ADC
AK5386 - 24-bits, 192kHz, 110dB SNR, -96dB THD, single-ended input
AK5385B - 192KHz 24-bit ADC
AK5384 - 4-channel ADC 107dB SNR, differential inputs
AK5383 - 24-bit 96K 110dB Wide Temp Range
AK5381 - Low-cost 96KHz ADC 106dB w/defeatable HPF
AK5366 - 103dB 48kHz 24-Bit ADC with 5ch Selector, IPGA and ALC
AK5359 - 24-bits, 192kHz, 102dB SNR, -96dB THD
AK5358A - 24-bits, 96kHz, 102dB SNR, -92dB THD
AK5357 - 24-bit low cost, low power ADC for consumer applications
AK5356 - Low-power ADC for portable applications
AK5354 - 20-bit 48K 89dB with 2-input selector, IPGA
AK5353 - 24-bit 96K low-power, small size, 96dB
Rafael
ADC
Texas Instruments
Wolfson
Wavefront
AL1101G 24bit 107db
AL1201G 24bit 107db
Thaler
ADC150 18 - 24bit
ADC180 13 - 26bit
Intersil
HI7190 24bit
HI7191 24bit
Cirrus Logic
Analog Devices
AKM
DAC
Texas instruments
Wolfson
Cirrus Logic
Analog Devices
Maxim
AKM
Rafael
