Adding GR meter to Craig Anderton compressor using second vactrol?
Blue Jinn
USA Northwest
Hello,
Assumption: I can borrow the meter circuit from Johan Blomdahl's "LA-Light" (top schematic) and wire a second (NSL-32) Vactrol with the LED in opposite direction. The "LA-Light" uses VTL5C2's that are on: 200Ω/40mA,  dark 1M/24mA. The NSL-32 is 500 and 500k respectively, but I don't see the values for the meter circuit requiring any adjustment. (The component numbers are my own notes.)
The question: I'm assuming I'm doubling the current draw by adding the second LED, so I'd need to halve the 1k5 resistor (R1) driving the vactrol LEDs. I can't seem to get the math to work out from the datasheet for the CLM6000/NSL-32, but it seems logical. Anyone see any problems?
  • IMG_4091.pdf
    885 KB
Blue Jinn said:
Hello,
You'll probably need to adjust the 68k and 47k resistors (R6 & R14) in order to get a usable reading.
No. That would be true if the LED's were in parallels, but they are in anti-parallels, so when the voltage is positive there is no change, though it's different when the voltage is negative.
