Yes, that's what kinda through me at first. I heard the noise and changed in over to another pre and the issue went away. I think I will play with lowering the 48v and seeing what happens. Thank you so much!Have you tested your mic with another preamp?
Yes, I thought about that. I was going to do a LM317HVT, but they are out of stock with my favorite parts suppliers, so I moved on to this way. I've brought it down to about 30v and haven't got the "whine", but would like to go lower... below 12v I think.You're better off with a pot controlling the voltage setting on an LM317.
Here’s a couple of quick things to try to rule out RF interference ( please ignore if you’ve already done this)So, we have done more tests and the issue seems to follow the length of cable we use and perhaps how many connections it goes through. The longer the cable to more the noise is there. The issue shows up very strong with about 50' of cable, and drops to nothing at 3'. The noise also seems to be more like 5kHz, but may have been different the day I did the 1st test.
Something with microphones and long cable runs?
