Paul B
OK, other Paul character is back.
[quote author="CJ"]Voltages look good on your 6AQ5 output!
Something is fishy on you input circuit. The Sowter has a 1:4 ratio, so you should be seeing an increase in ac volts as your source goes thru the input transformer. Also, if using an XLR jack, you measure your signal between pins 2 and 3. Pin one is usually the shield.
Try ditching the DI box and just hook up a cd signal straight into the LA2. Measure input vs output on bpth sides of the input transformer. Also make sure your lim/comp sw is wired right.
cj[/quote]
I wired the input straight into the bloo. The input signal measred an avg. of about 300-320 mV with peaks at about 450. This is about the strongest signal I can put into it without it distorting at the output, even at the lowest levels. By the time I turn the gain to 10 it is already about 3 times as loud as not running throught the bloo, and starts distorting at about 20.
With this 300-320 mv avg, I was getting a reading of about 1100mV average at the R5-R6 junction (w/ the blue sowter input tranny wire), with peaks at about 1640mv.
Using a 313mV strong 1k sine wave straight into the bloo, I got a reading of 1153mV at R5-R6. So it seems Im getting more like 3.7:1 ratio rather than 4:1.
with that 313mv sine wave I got these readings also:
495 mV at R6-R7 (insulated turret) and at top of R2
114VAC on both sides of C9 with PR at 100, 58.4V w/ PR at 50
as far as output, with these gain readings I got the following output readings at the output jack:
gain at 10: 215 mV
15: 712mv
20: 1268mV (reading 0db on the VU meter)
25: 1672mV
30: 2.6V
The VU meter was pegging by the time I got to 30 with the sine wave so I didnt test it any higher than that.
With the signal hooked straight into the bloo, it seems to only lower the distortion threshold on the gain knob.
thanks,
Paul
cj[/quote]
gain at 10: 215 mV
15: 712mv
25: 1672mV
30: 2.6V
thanks,
Paul
