OK, here is a voltage chart for the LA2. I used my own machine, which utilizes a 12AY7 for V1, but that should not make that much difference for troubleshooting purposes. Just expect more gain from V1 from the 12AX7a.
Also, my 6AQ5 is really a 6V6GT, the exact same tube, different bottle, so that should be ballpark also.
I am using an external pwr supply, so the B+ comes straight into the box, thus, I did not include pwr supply ac volts.
File is a bit large thus I am linking it. Filp it left or right to get it to print on one page. Colors will be lost on B/W printout.
I injected real music from a CD player, set the GR on 5, set the gain pot so I was reading 0 db on the meter output. GR registered about minus 20 on the meter. My VU meter is not perfectly calibrated, so allow 20 percent difference in all of these readings, which is normal for a tube circuit anyway.
Now go get that problem, Paul! Rework be damned!
:thumb:
http://vacuumbrain.com/The_Lab/TA/LA2/la2_voltages.jpg
:thumb:
