dissonantstring
hi steve,
o.k., i'm retarded!
for the benefit of others i'll post this...
i left the wire which is connected to the + and - lugs on the beede vu meter and that is why i couldn't get my vu to zero out. took it off and i can now zero out my meter in GR mode with the zero adjust pot. do they put that wire in for stablizing the posts on the meter during shipping?
anyway, when i did the test you suggested (sending +4 dBU 1KHz sine wave into the unit with +4 selected on the meter switch) there was no reflection or movement on the meter. it just sits to the left at -20. i triple checked my rotary switch/ mini turret board/ front panel pot wiring and all looks as it should be though as i stated before i'm retarded so i could definitely be wrong. i tried to adjust my peak reduction and the needle on the vu does not reflect compression, though the signal level does become audibly softer when i increase PR. oh, i have an extra T4 i got from JBL and tried to stick that in to see if my bloo T4 was wired wrong, but got the same results.
i'm at a lost now. any suggestions?
thanks.
-grant
o.k., i'm retarded!
thanks.
-grant
