[quote author="CJ"]What happened to Paul B? We either fixed him, or he jumped off a bridge somewhere.
:?:[/quote]
Yeah, you fixed me, for the most part :grin: :grin: :grin:
Now comes the hard to admit part. The crux of it is right here:
[quote author="CJ"]Paul, do you have a mic and a mic pre laying around?
If so, plug that in and see what happens.
It could be that your LA2 has been working as it should this whole time. I have seen that happen before. Maybe you are just over driving it,
cj[/quote]
Ive been feeding the wrong kind of signal into the box. I have been taking the CD output signal from the monitor/speaker outputs. I had in fact run tests with a preamp but it was with the same signal. I used a mic into the preamp and then into the box. The signal has to be really hot for the box to compress to the levels I've seen posted by others. The signal coming out is still very hot but it is usable. The gain is working much smoother. The unit is VERY quiet.
So I would bet my box has been working for the last 6 weeks or so.
Now I could use a cooler input level, and just crank up the PR (with lower input levels I need to turn PR to 70-80 to get about 10dB reduction) because i probably wont be needing 20-30 dB PR, to tell you the truth! I've not messed with it much so Im heading out to go twiddle knobs and flip switches here in a minute.
CJ, do you think it would help to put the 100k's back in for R9 and R13? Im still running the AY7.
