MagnetoSound
Thanks, PRR.
Yes, my interpretation of tube data sheets leaves a lot to be desired ... why do they suggest 10mA plate current? ... perhaps the assumed application is not relevant here?
Right, it is the reflected AC impedance that is of concern as far as the signal is concerned, not DC resistance - and the grid-cathode voltage is the stopper in the bottle for DC current ... so I guess not even the internal Rp matters then, when biasing the tube?
PRR said:> the plate current to aim for in Class A operation as 10mA or so ...
WHY? (Hint: no, you could do "Class A operation" with much less than 1mA...)
> one might assume around 7k in the winding ...
And one would be wrong. You wish for zero DC resistance in the winding. You bias-down the tube somewhere between maximum and zero by setting grid-cathode voltage.
This gives terrible DC gain and output. But we don't want DC signals. The AC impedance is higher than the DC resistance.
