pucho812
Does anyone have a schematic of the 9098 preamp eq rackmount?
Sorry, it's the console, not the rackmount preamp...There is a 9098i in the Technical Documents
That is correct.Sorry, it's the console, not the rackmount preamp...
Very few companies design a chassis so that you can remove top and bottom lid and access the circuit boardsGreetings,
I'm working on one of these 9098i rack EQs for a client; Serial # A002580a. Strange behavior with some bands working, some not, distortions and odd interactions between them. I found resistor R-12 burned open. Replacing that showed the negative 18VDC rail for the mid eq bands is shorted to ground. The board is pretty densely packed and to remove anything requires major disassembly. Why companies build these expensive devices without a removable bottom panel is beyond me. I'm guessing a shorted cap, but.........
Before going thru that and a hunt and peck process, I was hoping someone might have a print to share. I've tried everywhere I can think of with no success. I'd really appreciate it and be glad to reimburse expenses, trade docs or whatever. I'd like to get this unit off my bench and back to my client. Thanks much for any assistance/suggestions!
Regards, Jim
Very few companies design a chassis do that you can remove top and bottom lid and access the circuit boards
The classic UREI gear (1176 and LA-3A) also had the removable top and bottom covers for service.Chandler does this. It's super convenient and wish more did it.
So does Avalon design. The pcb’s in their gear mount to chassis frame from the sides so that if I take off the bottom lid, the circuit boards are still mounted. Same with the top lid. It’s more expensive to do but it makes service much easier.Chandler does this. It's super convenient and wish more did it.
It was an relatively early 9098 desk....split monitoring....vs the later 9098i....inline monitoring. It had more than a few random failures of 100 nF mono ceramic power rail bypass caps. The Amek USA tech folks told me that was a known problem, and originally said it was due to the caps having an incorrect voltage rating. Later, they just said it was a bad batch of caps.Didn't the Amek 9098 desk have a problem with ceramic de-coupling caps being the wrong p/n? It was something like they were 10v rated caps instead of 100v and they would fail short from being across the audio rails. I seem to remember Brian Roth having to change thousands of these caps on a desk somewhere in the last millennium...
