AML 52F50 issues
MHProd
Member
Vancouver, BC
Hi everyone,
I just finished building a pair of 52F50 and attempted to calibrate them but quickly ran into an issue...
One calibrated fine.
I started the other one, adjusted the bias to 130mA and then as I was trimming the output, my meter went close to 0 suddenly.
Checked the probes, checked the input and then I started to smell something "hot", I checked the the bias resistor and it was drawing 345mV... Tried to turn the bias down (or up) and no effect on the reading.
I might have fried something but since there are no voltage test points in the manual, I'm not sure where to start...
Thank you for your suggestions!
Yes, I'm measuring it across R156. It worked fine initially but like I said, I lost my output signal and it started to smell like hot plastic. The bias trimmer doesn't change anything and it's now drawing almost three times the specs... I was getting a very stable reading over the resistor on both units. Now this one just shows 345mA...
Thanks, I had read this thread before posting.
