I replaced all the power mosfets in this bass amp but it is clipping. There seems to be an imbalance in the bias voltages such that the source-gate voltages are incorrect,
Here are the voltages , maybe those two transistors with the red arrows are not biased right?
Also, what is the purpose of the opamp circled in read, some type of feedback maybe?
Thanks for any help!
PS: the spreader circuit in the middle of the two transistors has the abillty to make the offset voltage at the speaker terminal go to about plus 50 volts. Over...
