dimebucker
Member
- Joined
- Aug 2, 2017
- Messages
- 10
Hi all
I'm getting a 440 soon with the DC servo capstan installed. I wish to do some Beatles-type experimentation with varispeed around the 15ips setting.
(From what i've read it seems they would typically record around 5% slower or faster and then playback at normal speed.
This created an interesting subtle effect, particularly with vocals.)
From the manual it states that an external oscillator can be used to control the speed:
Can anyone suggest a set-up that I could use?
I'm pretty much novice in terms of electronics, but have put together many kits, including preamps... I can solder well
I was thinking i'd need an Oscillator with at least:
-frequency control knob
-LCD display so that I can see when i'm back on 9600Hz (or is it 4800Hz?)
-maybe the potentiometer should have an indent, so I can easily 'click' back to 15ips.
Any suggestions would be much appriciated
