sverige_cruz
Hello everyone,
My friend and I are having a bit of trouble (i.e. Pain in the arse) setting up his AMPEX MM1100 8-track. I will begin with a history of its problems, and perhaps some/few/one of you can help us out, please?
* got the machine from seller - played a test tape (tones) but would gradually slow down
* started to blow the fuse for the 27V power supply - no power to reels or transport control box
* checked transistors in 15/27V power supply - replaced 2 (2N4348)
* turned on machine - stayed on - in play mode (tape or no tape) take up reel spins - capstan does not spin - pinch roller does not engage - transport control box lights went out - VU meters sitll on - could not stop take up reel - shut down machine
* cursed the guy who sold the machine
* replaced the opto-isolators in the MDA - replaced 6 faulty transistors in the MDA - replaced fuses
* turned machine on - checked voltages 15/27/39 all OK - attempted to normalize reel servos & make tension adjustments
* in play mode take up reel spins (with tape on, it becomes very tight) - lights on transport control box out - capstan does not spin - capstan pinch roller does not engage -*BUT* the fuses are still intact - after waiting about 1 minute, flipping the power switch turns on the machine - rewind/ff/stop work - play doesn't engage capstan/roller, but engages takeup reel
so...this is where we're at now... stuck with protools till we fix this thing. Any & all help is GREATLY appreciated!
Best Regards,
Jesus Cruz
Best Regards,
Jesus Cruz
