AardvarkBry
Tinkerer who doesn’t know nearly enough to fiddle
When I switch it to mono mode, I get the same signal out of both the left and right output, when it’s only supposed to come out of the left. When I switch to stereo, I get a normal signal out of left, but the faintest signal out of the right.
I’ve checked every voltage in the entire machine, and everything is pretty much spot on, until I get to the cathode follower output. On the cathode side of C6 and C11, I’m getting 34volts on both, but between the capacitor/resistor and the switch, I get 1volt output on the left channel, but only 100mv on the right channel, whether or not it’s switch into mono or stereo. If I check the output jack, in mono, I get 1volt on both, but in stereo, I get 1volt on the left, and 100mv on the right.
Is this a problem in this old 1959 switch, or is the problem in the c11 r25 combo? The capacitor is an old poly bumblebee, and the resistor is an old carbon comp.
