pucho812
need to make a converter on vero board so that client can put a doa in place of a single channel IC opamp. I want it to be as reversable as possible just in case things don't work like the guy wants...
analogguru said:Here you go:
http://www.conrad.com/ce/en/product/183858/Adapter-Sockel-mit-gedrehten-Kontakten-Assmann-WSW-AR-08-STT-Pole-8-Rastermass-762-mm-Material-PBT-Kontaktmaterial-Me
pucho812 said:need to make a converter on vero board so that client can put a doa in place of a single channel IC opamp. I want it to be as reversable as possible just in case things don't work like the guy wants...
Any design can benefit from discrete opamp upgrade. You can expect a "bigger" more "powerful" sound.
SSLtech said:From the acsoundstudio web link:
Ha!!!
-Please excuse my cynicism...
pucho812 said:Analog guru found me exactly what would work![]()
mnats said:pucho812 said:Analog guru found me exactly what would work![]()
You must have missed it but unlike the Assmann the one I posted has slotted posts rather than simple pins on top. Much easier to solder a wire to...
