Got a 651 with a fried transformer. Anyone know what the voltages are on the secondaries?
Pat
Austin
Pat
Austin
Thanks @pucho812 and sorry for the delay. It has a 7815 and 7915 same as in the schemo. So if the unit runs on +/-15VDC, would I use the formula 15VDC*1.4(rms) = +/-21VAC to get the transformers secondary voltage requirement?what regulators are used on the unit? Unit runs of +/-15VDC based on the schematics.
schematic is here
It's the other way around - AC RMS voltage gets multiplied by 1.4 (or sqrt(2), rather) minus a diode voltage drop, to get the raw DC figure.
Working backwards, you'll want to add 3-4V to the +/-15V to allow for regulation headroom for the 78/7915, and dividing that by 1.4 gets us to about 13V AC. That's an unusual value though. A 12-0-12VAC transformer might be a bit marginal, so you should be safer with a 14-0-14 or 15-0-15 one (aka. 28-30V center-tapped).
