robomatique
[quote author="Mike Keith"]If you use a LED for the phantom use a 15K in series, you could also place a 33K across the 48V will also dissipate the voltage a little quicker. That's what I use on my JM 130 mic pre and works just fine..[/quote]
So you mean a 33K resistor permanently across the 48V and 48V ground? That doesn't effect the normal phantom? Or would it be better to use a lower value and just swap it in when phantom is bypassed? Or does it matter?
Thanks again!!!!!!!!!
Robetr
Robetr
