Mike Keith
I would say the schematic in flawed, disconnect the 2 caps feeding the 48V and see if it doesnt start working properly.
That's what I meant. the reg might be happiest with around 12v to reg to 5v, since it 's probably not straight DC at C1/R1, so dips/peaks.How much voltage do you have on the input of the regulators?
Yeah, even the real API preamps seem to sound worse when using an input pad.
There was some discussion a while back about implementing an output pad instead.
OSA uses a pot on their output, which seems to work OK for me, but I haven't investigated how good the circuit is and how much it changes the sound really.
depending on the mic used the pad can load the mic.
the GND on the opamp board is used for 100n caps between +v gnd and -v gnd.
I'm fitting mine under the board. This GND is also used by the original maker to shield the opamp, I have been told about some unetched board connected to GND over the opamp board.
Someone said that a metalic case grounded around the opamp is a good idea...
I think the empty GND hole was for the shielding...
I have another issue that isn't much more than annoying.. at the highest and lowest gain settings I have an incredible amount of hiss. the audio does not seem distorted and is otherwise clean but has a loud hiss much like turning an open fader all the way up. I saw that someone mentioned the opamp oscillating but this doesn't quite sound like any oscillating opamp i have ever come across.. but that doesn't mean much..
