rbaker
I'm just about ready to order the rest of my parts for 2 312s from fabio (his 2520's and boards showed up yesterday)
I was given some older mci channel strips which I had originally intended to rackmount but it just didn't look like it was going to happen. The strips have jensen je-115k mic input transformers so I figured I'd use those.
I using greg's part list for the guide and he used jensen 110k's. I realize that they are not THAT much different (1:8 instead of 1:10 mine) Could someone explain how the increased ratio might affect the sound? more gain/more aggressive etc?
Also I was looking on the jensen site and each has a diagram of typical use for each transformer (which closely follows the fabios schematic) the resistor that connects two of the secondary leads on the 115k is 150k. on the 110k it is 100k, which is also what is specified on fabio's part list.
#1 if I use my 115k's should I change to that value (150k)?
#2 are there any other resistance values that I should change based on this transformer? if so how might I figure those values? (trying to learn something here rather than simply getting the answers)
In a completely unrelated question, greg's bom has switches that are $8 each. Is that required (ie: is there something I'm missing?) or are they just really nice switches?
