[quote author="AnalogPackrat"]
1) D2 is a double diode (two diodes in series, both with the same polarity so you get a 1.3V total drop across them)
2) C2 should connect to - in rather than the base of Q3. Simply pop out the leg closest to the - in pin and connect it to the stub of the pin that sticks out on the top side of the PCB. It might be easier to pull C2 and replace with a new on leaving one lead long enough to connect directly to the top of the - in pin (that's what I did).
A P[/quote]
Thanks A P
I'm gonna fix #1 and #2.
I've already made the C5 correction mentioned in #3. The 100pF cap is under the board.
A P[/quote]
Thanks A P
