mick
Ok so I've posted a diagram of how I wired a DPDT switch ( NOT PCB MOUNT) to Fabio's board. It's colour code for the connections to the board, you can see I swapped the ground to the wiper so when the phantom is switched off the CCP1 can drain through an (insulated) link wire on the switch to ground. I upped the RPP3 resistor to 1K just to slow it down a little when it drains, I hope this helps.
http://www.twin-x.com/groupdiy/albums/userpics/phantom_drain_2.bmp
Mick
Mick
