dawsonaudio
One of my lunch boxes has an API 560 that is making some scratchy/crackling sounds. I've got four 560's and two 550A's in the box and it's the only one making this noise. I've removed the input cabling from the bad channel. I swapped the output wiring with the channel next to it and the problem stays with the module. I assume the 2520's going bad. Anyone else have a similar scratchy noise with an API module? I don't have any opamps to swap, but I did open up the module and everything is seated fine. Should I swap one of my other 560's opamp to see if that's the problem? Unit is probably 4 or 5 years old. I'll call API tomorrow, just wanted to get a jump on other possible troubleshooting ideas.
Thank you,
Nate Dawson
Thank you,
Nate Dawson
