API connectors
echorec
Stockholm, Sweden
Hi, I´m planning to rack some API EQs. Where can I find the mating connectors? Also, which PSUs do you use when you rack API modules?
Thanks in advance!
You can get them from Mouser or Digi-Key. They are manufactured by EDAC. I think the part number you're looking for is 306-015-500-102.
Someone double check that. :thumb:
For a power supply there are a few +/-15V designs around the forum. But JLM's is great for the novice builder.
http://www.jlmaudio.com/JLM Power Supply.htm
Good luck to you.
