EmptyMusicBox1
hello DIYers !!!
I have a question about to add a Input transfo on my SSL9K preamp !
i have bought a NTM1 Professional studio transformer 1:1 (Mic input) :
http://www.neutrik.com/en/accessories/transformers/ntm1
But i don't know how i can integrate it on my project... because when i use a LINE level on the Input i think the transfo make distortion no ?
I have a JLM go between for a phase/48v and PAD maybe i can add the transfo after the 20db PAD when i use a LINE input ?
it's correct ?
How i can wire the ground pin ?
If i want to add an tranfo on the input i need to add an other on the Line OUT of the SSL9K for a perfect ground isolation !
i have bought the NTL1 :
http://www.neutrik.com/en/accessories/transformers/ntl1
I think i can add it directly after the Output for have a Balance OUTPUT but how i can wire it for do that correctly ?
thanks for your help
it's correct ?
