How do you feel? Uncertain about mixing/judging highs, or stereo balance? (It was stereo balance that I had to self-denial for years before getting checked; I'm halfway monophonic.)
Exposure? Age, guns, loud speakers, head infections?
You appear to have plenty of high-droop, typical of older ears or over-blasted ears.
The left ear is not so bad. The 250 Hz dip is odd and may suggest a mechanical problem (fixable). However this is probably no connection to the high-droop. (It may be a bad test.)
Get a Bone Conduction test!! Anywhere above a mobile test screening, bone-conduction should be available. (Don't fret: they they don't drill a bone, they put "earphone" on skin at temple or cheek.) If the BC shows large high-loss, you've got burned-out inner nerves. Fix is unlikely. If you have highs through bone but not through air, problem is between outer ear and inner nerves, there *may* be something to fix it.
Wear protection!! For anything possible! Certainly for mowing, sawing, and other activities.
