balanced to unbalance +4
ilfungo
ITALY
I need to unbalance the outputs of a Digi 192 to connect them to a Amek M2000 (unbalanced line)
I discovered that if I send the signal to Amek, I lose about 10dB input ....
It is a problem of digi 192.
Can you tell me a simple and economical to do it?
you can do balanced to unbalanced connections with a simple cable, that will give you about 6dB loss but that is usually not a problem since the line amp of your console can make up for it.
wire your cable like this:
tip (or xlr pin 2)= hot
connect ring (or xlr pin 3) to sleeve (or xlr pin 1)
done
good luck
