CJ
Came across an interesting phenom while working with current transformers.
There are clumps of magnetic domains in core steel used to stamp lams.
Depending on the quality, there could be some rather large clumps.
Trick is, they can get hung up, they might need a little more juice to get them to switch.
This only shows up if you move up the B-H curve Very slooowly.
What happens is, say you inject a current into the primary.
The voltage across the burden resistor on the output of the CT will not form a straight line when plotted against input current.
So when the clumps flip around, you get irregularities on your graph, something that has been driving me nuts for years until now.
They say to use a pen when doing lab work, now I know why.
If you "cheat" your data points closer to being linear, with a pencil, you just erase.
And you erase the Barkenhausen effect that you are trying to dismiss as sloopy lab equipment or operator error.
With a pen, when you discover this effect, you can go back and see your that chicken scratched graph points that got shoved over a little bit were really right in the first place. So always use pen, and cross stuff out.
Here is a pic of what I am talking about. If you slowly increase the primary current, you can see the effect as an un smooth B H curve, the irregularities due to Mr. FunkenBarker
How this has anything to do with audio is up to you people to figure out.
Don't shoot the messenger!
cj
Kind of like discrete electron orbits, only a lot closer together.
This is a good reason to not be wasteful and slam the core with close to what it will take in the way of B max.
That way, you muscle thru this stuff with enuff horsepower to negate the effect, whatever that effect might be.
cj
![barkenhauser_laminations.jpg](https://proxy.imagearchive.com/60d/60d1dd0dc38f2d0309113c92edf6119e.jpg)
