soapfoot
Hello! I've got an old Signal Corps BC-730-B limiter. It sounds great, but if the limiting threshold trimmer (R10) is advanced too far clockwise, motorboating occurs (all caps are fresh and new; all resistors are new 1% metal films)
It has always been this way, and I suspect it's inherent in the design as the power supply doesn't look to have too much decoupling.
I notice that if I add a modest amount of capacitance to (2µF seems to do the trick) between R7 and ground (at the junction of the plate of V4) the amp stabilizes and the motorboating goes away.
My simple question is--will this modification have any side effects besides stopping the motorboating? Will it impact the sound of the limiter in any way? V4 is essentially the detector circuit of the limiter. Is it fair to assume that adding capacitance there may alter the bandwidth of the detected signal?
I admit to knowing only enough to be dangerous, so I figured better to ask for help before modifying.
Thanks in advance!
Thanks in advance!
